Recognised Expert
Message 31 of 50
Re: Persisten disconnects
@StephanieGwrote:
Hi @pompey1898
Thanks for the update. So far so good, however I'm still due to catch up with you on Sunday so let's see how it goes then 🙂
So far, not very good.  I had a disconnection at 22:03 yesterday
Recognised Expert
Message 32 of 50
Hi @StephanieG ,
Just for the record I had a disconnection at 23:14 yesterday.
Speed test result :-
Recognised Expert
Message 33 of 50
Most disappointing that for the third time in nearly a year BT are unwilling, or unable, to fix these daily disconnects.
Do the CL's and Gurus think I should consider raising the issue with the ombudsman ?
Message 34 of 50
from all your posts on the subject BT Retail appear to have arranged numerous openreach visits to try and solve your problem but any solution appears short lived.  I think the best you will get is the ability to leave your BT contract without penalty  up to you about ombudsman
Recognised Expert
Message 35 of 50
Hi @imjolly ,
Thanks for your reply and suggestion.
I have not had numerous Openreach visits, if I remember correctly it was one.
@StephanieGDid not offer the ability to leave penalty free.  Assuming the problem is caused by a line problem, that would move with me would it not ?
Message 36 of 50
If it is a line problem then it will follow you whichever ISP you choose apart from virgin
you could always ask @StephanieG  if you can leave penalty free and see what she says
Recognised Expert
Message 37 of 50
Hi @StephanieG ,
Since you moved me down to a 55/10 package failed to cure the disconnections issue can you move me back to the 80/20 package I was on please.
I know I can’t take advantage of that at the moment but Openreach have laid fibre to the village in readiness for us to get FTTP.
Recognised Expert
Message 38 of 50
Hi @StephanieG &@imjolly  ,
Further to my last post I have looked further into my connection, so what do you make of the following please ?
My Downstream speed has dropped to 40Mbps.  Have I been banded or reduced to a 40/10 package ?
Also my IP Profile is now 88% of my Downstream speed where it used to be at 92%.  What does this indicate ?
Stats & speed test results as follows :-
Moderator
Moderator
Message 39 of 50
Hi @pompey1898 thanks for posting, @StephanieG is not in the office this week so I've sent you a Private Message with details on how you can get in contact with the mod team and we'll be happy to take a look.
Message 40 of 50
@pompey1898
your package has not change just the DLM has eventually taken action with all resets and now banded your connection
