pompey1898
Expert
Message 51 of 53
Re: Persistent disconnects
Hi @imjolly,
Result posted below as requested.  Unusually slow this morning.  Download speed normally 35Mbps.
pompey1898
Expert
Message 52 of 53
Hi @imjolly,
Did the speed test result give you any ideas then ?
Message 53 of 53
not really     your profile is as you say 88% of connection speed and seems to precise as if it has been set to help line stability  if that is reason then it is working for you
