Message 1 of 7
Please can you remove Interleaving?
Can I please have Interleaving removed from my line? @RobbieMac or any admin who can help me do it.
Tags (1)
6 REPLIES 6
Message 2 of 7
Re: Please can you remove Interleaving?
Hi @costagg2019,
Welcome to the Community and thank you for posting.
Interleaving is only applied to a line if it is needed to help improve the stability of the connection.
To get a better understanding of what your connection is doing, please could you post your router stats?
To get your router stats type bthomehub.home into the address bar. This will open the Hub Manager.  Click ‘Advanced Settings’ and then ‘Technical log’.
Paddy
Message 3 of 7
Product name:Smart Hub
Serial number:+088047+1823001129
Firmware version:v0.09.06.25010-BT
Firmware updated:Mon Jun 15 08:04:09 2020
Board version:01
DSL uptime:0 days,12 Hours35 Mins34 Secs
Data rate:4.422 Mbps / 31.933 Mbps
Maximum data rate:4.423 Mbps / 37.294 Mbps
Noise margin:6.0 / 6.3
Line attenuation:38.3 / 25.6
Signal attenuation:27.4 / 23.0
Data sent / received:397.9 MB / 7.3 GB
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BTHub6-W6JM
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:BTHub6-W6JM
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:BC:30:D9:72:67:6B
Software variant:-
Boot loader:0.1.6-BT (Fri Sep 9 10:05:09 2016)
Message 4 of 7
My ping is 45 i want it lower. My connection is stable i just want a better ping for gaming. Ping used to be lower.
Message 5 of 7
You are on an FTTC connection (Fibre To The Cabinet). It is not possible to make any alterations to these types of connections, as they are controlled automatically by DLM (Dynamic Line Management).
Make sure you always use an Ethernet connection to your gaming device, as wireless will suffer from interference.
Message 6 of 7
as you have a HH6 I would suggest splitting the wireless networks and also select channels manually instead of auto  use a wifi analyser hone to find a free or less congested channel
Split the networks
Message 7 of 7
I don't use wireless. My pc is hardwired to router. And the router is wired directly into my master socket. No extensions.
