martin4
Message 11 of 48
Re: Please help...Internet is working but not loading some websites
Is it possible to switch IPv6 off on the smart hub?
Foxcliffe
Message 12 of 48
What does your WAN log look like?
martin4
Message 13 of 48
Category: WAN
Time and date / Message
00:01:35, 01 Jan.
:WAN: SENSING AUTO VDSL
00:01:14, 01 Jan.
ptm0.101:VLAN VLAN_DATA connected
00:01:14, 01 Jan.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:14, 01 Jan.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:14, 01 Jan.
dsl:VDSL link Up: Down Rate=18327Kbps, Up Rate=6073Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
:WAN: ethernet as LAN
00:01:23, 01 Jan.
00:01:04, 01 Jan.
00:01:04, 01 Jan.
00:01:04, 01 Jan.
00:01:04, 01 Jan.
dsl:VDSL link Up: Down Rate=17954Kbps, Up Rate=6101Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
20:51:30, 22 Mar.
dsl:VDSL Link Down: duration was 772 seconds
20:51:30, 22 Mar.
:VLAN VLAN_DATA disconnected
00:01:29, 01 Jan.
00:01:13, 01 Jan.
00:01:12, 01 Jan.
00:01:12, 01 Jan.
00:01:12, 01 Jan.
dsl:VDSL link Up: Down Rate=18114Kbps, Up Rate=6080Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
20:36:53, 22 Mar.
dsl:VDSL Link Down: duration was 2673 seconds
20:36:53, 22 Mar.
00:01:26, 01 Jan.
00:01:06, 01 Jan.
00:01:06, 01 Jan.
00:01:06, 01 Jan.
00:01:06, 01 Jan.
dsl:VDSL link Up: Down Rate=18509Kbps, Up Rate=6356Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:25, 01 Jan.
martin4
Message 14 of 48
Router was off last night btw.
Checked2013
Expert
Message 15 of 48
As you've said that it works fine when you use a VPN then it shows there is nothing wrong with your physical connection and your logs support that
martin4
Message 16 of 48
Yes, I have no idea where is the problem. I tried everything It works 100% for every device when I download something. I set something to download from PSN Store, and everything magicly starts to work. Normally i have to refresh many times webpage to load( BT own website for example) It seems like certain connections don't seem to be live...
Checked2013
Expert
Message 17 of 48
Try to change the DNS settings for both IPv4 and IPv6 to google's DNS and see if that helps
martin4
Message 18 of 48
This forum struggle to load too, on wired connection. I have to use mobile data ( or start downloading something)
martin4
Message 19 of 48
I have tried on pc, android...not possible on the smart hub itself but I was able to change DNS on the Netgear6400, still no success.
martin4
Message 20 of 48
It all started to happen when I was using hub 5, then I bought Netgear. After that they sent me new smart hub...same problem on all of them
