Checked2013
Expert
Message 21 of 48
Re: Please help...Internet is working but not loading some websites
Are you connecting directly to the smarthub or the Netgear?
martin4
Message 22 of 48
Smarthub
martin4
Message 23 of 48
I tried everything with Netgear( more options) and reverted back to smart hub(in the case/hope of an update)
Message 24 of 48
What happens if you switch off and disconnect all your devices from the Smarthub and disconnect any powerline adaptors and only connect one device directly by Ethernet to the Smarthub?
Foxcliffe
Message 25 of 48
Have you tried booting in safe mode with networking (so you can surf)?
You could first try booting your browser in safe mode if it has the option or with all add-ons disabled if it doesn't.
Do you have anything that will use the 5Ghz frequency (or have you already tested both frequencies individually?)?
Have you done any checks for radio frequency interference? http://www.acma.gov.au/Industry/Broadcast/Spectrum-for-broadcasting/Spectrum-radio-broadcasting/what... you can use a radio to do this but I forget which (blank) frequency openreach use to track the problem down on.
Do you have access to someone else's internet connection - to try to reproduce the problem on a different network (or can you access a public network?).
PheeragHfre
Recognised Expert
Message 26 of 48
Have you checked the IPV6 settings of all the devices on your Local network/Adaptors?
This link may help a little?
https://www.sixxs.net/faq/dns/?faq=ipv6slowconnect
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
martin4
Message 27 of 48
I tried direct wired connection, same problem.
My next door neighbour connection is fine when I connect, everything is working fine (is on BT too)
PheeragHfre
Recognised Expert
Message 28 of 48
Which Homehub/Router is your neighbour using?
Is it being presented with and  using IPV6 addresses?
martin4
Message 29 of 48
He is using Hub 5, wchich i have too. Same problem on my hub 5, it was working fine 2 months ago(fo 3 years)
Checked2013
Expert
Message 30 of 48
Are you using the Hub5 or the SmartHub?
Also have you changed the DHCP settings on either?
