martin4
Message 31 of 48
Re: Please help...Internet is working but not loading some websites
At the moment is connceted to SmartHub. I did switch off DHCP on the smart hub to see if any difference but not. Havent tried on hub5(if i remember correctly)
Checked2013
Expert
Message 32 of 48
The settings on the SmartHub should look like the following screenshot with the same values
martin4
Message 33 of 48
THanks...This is excacly same settings as mine
Checked2013
Expert
Message 34 of 48
Try setting your computer network settings to the following making sure that IPv6 is unticked
martin4
Message 35 of 48
Thank you, i have tried that already...problem still there
martin4
Message 36 of 48
Thank you for everybodys help...still no solution to my problem, will switch providers in this case. Ive had enough of BT constant lies and mickey mouse customer service.
Message 37 of 48
have you tried your old hub instead the hub6 has a number of assorted problems
Message 38 of 48
another thought have you tried your hub at your neighbours to see if the problem still exists
martin4
Message 39 of 48
Thanks, will try when I see them...Half of the links not working for me on this website:
http://ipv6.cybernode.com/list-of-ipv6-only-sites
Google works, Facebook not working for example...
martin4
Message 40 of 48
Problem started on the old hub 5...i have tried my  neighbours router(hub 5) same problem.
