normo
Newbie
Message 1 of 3
Poor BT Inifity Speeds
Since getting BT Infinity 2 I have never seen downstream line rate exceed 25Mbp. Not really bothered me too much but am now interested in streaming 4K content so need a higher rate to avoid buffering, etc. From dslchecker I see the following - is there anything of concern in here that I should take up with BT? I've tried both a HomeHub and a TP-Link VDSL router - no differences so not sure if the problem is my end or with BT.
Thanks,
Normo
2 REPLIES 2
Message 2 of 3
Re: Poor BT Inifity Speeds
you need to post your router stats to show connection information
check for line noise  dial 17070 option 2  should be silent and best with corded phone
Distinguished Guru
Distinguished Guru
Message 3 of 3
I'll also add its totally pointless being on Infinity 2 as you can only achieve Infinity 1 speeds.
