RPR_Ford
Message 1 of 13
Poor SNR Downstream and Upstream - What can I do?
Hi,
Ive been having issues with the BT broadband cutting in and out or hanging as it feels. I upgraded to a Draytek Vigor130 Modem and Synology 2600 Router last month but still have the exact same issues.
I've bypassed the BT filter faceplate and checked my internal wiring and all appears good.
I still only see 2-4 (DB) on my Upstream and Downstream SNR.
Any advice please?
12 REPLIES 12
Message 2 of 13
Re: Poor SNR Downstream and Upstream - What can I do?
I moved your post as you are on FTTC not adsl
the 3db noise margin is giving you a faster speed but if your connection continues to drop then the DLM will take action and increase your noise margin
is there any line noise  dial 17070 option 2  should be silent and best with corded phone in test socket with filter
RPR_Ford
Message 3 of 13
Whats the DLM?
I don't have a phone to try.
Sage
Sage
Message 4 of 13
Dynamic Line Management.
Message 5 of 13
the first basic check with nay broadband problems is to see if phone has a dial tone and if so is there line noise  an investment of about £5 on cheap corded phone could save you the engineers call out fee of £85
RPR_Ford
Message 6 of 13
My friend have me a phone to check the line and I can’t hear any noise.
something BT can fix?
Message 7 of 13
are you connecting the modem to the test socket with a filter to see if that helps stability?
can you post current stats showing internet connection time and not just system uptime
enter your phone number and post results  remember delete number  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
h3x1e
Message 8 of 13
if you think it's the SNR causing the issues, then you can configure the SNR via the Vigor 130.
Telnet into the modem via it's IP,
and use "v snr" command
You can configure it form -50 to 50, 1 = 0.1dB.
You can use it for testing, but I would let the DLM do it's job if it's dropping out.
RPR_Ford
Message 9 of 13
Great thanks.
RPR_Ford
Message 10 of 13
Ive removed the faceplate and connected direct which gave me around 4-5mb more on the download but 1-2mb less on upload. The SNR stayed the same
