DrMagical
Message 1 of 19
Poor initial speed BT 'superfast'
BT started by Superfast broadband service yesterday - FTTC.  I should get around 50-70 down and 18 up (stayfast guarantee is  minimum 47 down and 17 up).
I've checked on http://www.dslchecker.bt.com/adsl/adslchecker.welcome and this agrees with my promise. Sorry cannot seem to copy the image to post here.
I know I have to leave it switched on for 10 days but the initial connection speed is 5 down and 8 up! It hasn't altered in the first 24 hours. Brand new house, BT install master socket, no extensions, good quality new line copper, no noise on line at all with quiet line test. Brand new hub.
Am I being impatient or is this very wrong?
18 REPLIES 18
imjolly
Message 2 of 19
Re: Poor initial speed BT 'superfast'
can you post your hub stats  advanced settings then technical log information
any line noise  dial 17070 option 2  should be silent and best with corded phone
have you turned off smart setup  http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
DrMagical
Message 3 of 19
Thanks, I'll post hub stats when I get home.
Quiet test seems perfect.
Smart Setup is turned off.
DrMagical
Message 4 of 19
Product name:
BT Hub 6A
Serial number:
+084317+NQ90985254
Firmware version:
SG4B1000E01E
Firmware updated:
09-Sep-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 22 Hours 48 Minutes 45 Seconds
Data rate:
8.64 Mbps / 5.29 Mbps
Maximum data rate:
8637 / 6363
Noise margin:
6.2 dB / 6.3 dB
Line attenuation:
24.6 dB
Signal attenuation:
0 dB / 24.6 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
255 MB Uploaded / 808 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-6SJ2
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-6SJ2
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
00:CB:51:B4:F7:F1
Software variant:
Boot loader:
9.2.0
imjolly
Message 5 of 19
are you using the test socket with a filter to see if that improves your connection speed  should connect router direct to filter
if still as bad then phone CS services and get free engineer visit as speed well below expected
DrMagical
Message 6 of 19
I have the dual socket faceplate that BT installed few weeks ago with new phone line. Don't think I need filter with these? DSL line in one, phone cable in the other.
DrMagical
Message 7 of 19
Do the noise margins and other numbers look like I should be getting - We estimate your:
• download speed will be between 53Mbps and 73Mbps
• upload speed will be between 17Mbps and 18Mbps.
DrMagical
Message 8 of 19
Actually just live chatted with BT and they're sending an engineer out Thursday as there is a fault, so can't criticise them. I was worried I'd have to wait 10 days before raising a fault request!!!
JohnC2
Moderator
Moderator
Message 9 of 19
Hi @DrMagical  welcome back to the forum and do post back and let us know the outcome of the engineer visit.
cheers
John
DrMagical
Message 10 of 19
Hi, just an update.
A BT guy came to the house today. He plugged his BT homehub in the test socket, told me my line has been 'capped' at 5 down/ 8 up and nothing he could do about that. Have to wait in now for someone coming next week from the OpenReach 'Boost' team......
Oh dear.....
