Ciara1
Message 1 of 4
Poor internet signal from Smart Hub
My internet has been very slow and cutting out for the last few weeks. This happens with the WiFi on my devices but also when my laptop is connected directly to the smart hub via the Ethernet cable.
I’ve talked to two BT techs on the phone and done every check they’re asked with no solution, both conversations 1 hr + long and both said they couldn’t help me as they checked and there is sufficient signal getting to the hub and the system won’t let them send out a technician or a replacement hub so I’m sitting in a contract I can’t get out off (over £200 to terminate contract early) and paying for a service I’m not getting. Atrocious customer support!! Has anyone else had a similar problem and if so any advice?! Thanks
3 REPLIES 3
imjolly
Message 2 of 4
Re: Poor internet signal from Smart Hub
can you post your hub stats  if hh6 then advanced settings then technical log information
if hh5 then troubleshooting then helpdesk
enter your phone number and post results  remember delete number http://dslchecker.bt.com/adsl/adslchecker.welcome
can you conenct to test socket with a filter to eliminate any internal wiring problems
have you turned off smart setup?
have you split the 2.4/5ghz networks?
Ciara1
Message 3 of 4
Which stats do you need exactly? I have typed in my phone number and received a table of results.
I have tried turning smart set up of and have also split the 2.4/5 networks but this does not make a difference
imjolly
Message 4 of 4
need the dslchecker table posted and also the hh6 stats from technical log information
