DaveTypeGuy
Message 1 of 13
Poor line speed, think I need a mods help
Hey ive been using the Bt infinity unlimited package for around a year now when it was first installed I was getting a nice 40 download speed and around 9 up, ever since then its been dropping and dropping just a little bit at the time but we are now at half or under half of what it was going as low as 10, at this point its barely worth me paying for so i am hoping you can help me fix this.
From reading some threads I see you can do a total line reset of some kind perhaps we can try this?
oh one thing to note im using a home hub 3.0 type B if that makes any difference
Thank you for your time
12 REPLIES 12
Distinguished Expert
Message 2 of 13
Re: Poor line speed, think I need a mods help
Hello and welcome to the BTCare Community Forums!
This is where customers help other customers get the most out of their BT products and services.
To say thanks for a helpful answer, please click the white star
Message 3 of 13
Please run the speedtest at http://speedtest.btwholesale.com.
Please go on to run the Further Diagnostics, then post the results including your Downstream IP Profile
and your Upstream IP Profile.
Cheers
DaveTypeGuy
Message 4 of 13
Thank you for the quick reply here are the results.
 Download speed achieved
during the test was - 18.66 Mbps
For your connection, the acceptable
range of speedsis 16 Mbps-19.36 Mbps
Additional Information:
IP Profile for your line is -
19.36 Mbps
Upload speed achieved during
the test was - 6.21Mbps
Upstream
Rate IP profile on your line is - 20 Mbps
Now while the test may say the results are acceptable i have to disagree as i started off at 40..was very happy at that speed, it never disconected while i was using it and i was downloading my steam library at 20 minutes per game (used to take about 8 hours so ..yeah i was laughing the whole time) it stayed that way for months then as i say gradually the speed has decreased to this or worse (10 has been the lowest i have caught it at) in small increments, currently this is slower than my friends broadband connection that he pays a fraction of the price for 😕
Message 5 of 13
Have you rebooted the modem recently?
DaveTypeGuy
Message 6 of 13
the home hub gets rebooted, the openreach modem does not get touched because the engineer told me to leave that alone something about speeds dropping and taking 10 or so days to get back up to where, is that the next step reboot the openreach modem?
Message 7 of 13
Yes, reboot the modem and redo the speedtest.
DaveTypeGuy
Message 8 of 13
Ok modem has been rebooted and test redone these are the new results unfortunetly they are pretty much the same but it was worth a shot
 Download speedachieved
during the test was - 18.71 Mbps
19.36 Mbps
the test was - 6.19Mbps
Upstream
Message 9 of 13
Looks like a line fault has caused your IP profile to be reduced.
What was the estimate for your line when you ordered Infinity?
DaveTypeGuy
Message 10 of 13
When I first ordered it the estimate was 40 down and I think it was about 10 up.
when the engineer came and set it all up I was getting 39.5 ish, have to say he was great was on a mission to get the full 40 alas he didn't manage it but I was ecstatic at 39 (up from 5)
and i understood it would probably drop a little, which is why when it reached 35-38 i was still perfectly happy
