Lauradguk
Message 1 of 3
Possible BT Infinity Disconnection Problems
I have similar issues.. I get an error message on my smart tv, cinnrvtion problem but the light on hub stays blue ? It's a wired connection hub is next to tv?? Had line tested said No problems?? I'm supposedly be receiving fibre but I'm not sure it is to be honest
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Possible BT Infinity Disconnection Problems
Hi @Lauradguk and thanks for posting.
I've moved your post so we can offer some help. Is there an error code message on the screen such as IPC****? Are you seeing this for all channels or on demand? Can you give me as much information as possible and I'll try to help.
Cheers
David
Lauradguk
Message 3 of 3
No jjust randomly comes up for a couple of seconds, then tv goes off... then comes back on again. Im using a smart tv and its the channels we get via the internet.  The blue light on the box always stays the sames?
I have unlimited bt infinity 1, but even though its supposed to be fibre its still quite hit and miss on sppeds
