Gabloe
Message 1 of 10
Possible line congestion at peak times?
Over the last weekend and this evening I have experienced what appears to me to be line congestion. I am on a wired connection into my router, so it's not a wifi issue. I've shut all other devices down and run speed tests and it's great off peak, but really slow at peak times.
Could you check my cabinet for me please, for signs of peak hours congestion?
I enclose a screenshot of my details below from the BT Broadband Availability Checker.
Here's a speedtest I ran a few minutes ago. https://www.speedtest.net/result/8032393067 (Ping and upload great - download is moderate, but a lot slower than normal.)
9 REPLIES 9
Message 2 of 10
Re: Possible line congestion at peak times?
can you run btspeedtester and when first test completes run diagnostic test and post result must be done with wired connection
http://www.speedtest.btwholesale.com/
Gabloe
Message 3 of 10
Thanks for your response. Here are screenshots of the test and diagnostics.BTSpeedTest.JPGBTSpeedTest2.JPG
Gabloe
Message 4 of 10
Here is a speed test for an "off peak" comparison. (I didn't shut everything else down for this one, but did for the earlier test).BTSpeedTest3.JPG
Moderator
Moderator
Message 5 of 10
Hi @Gabloe
Welcome to the Community and thanks for your post!
Sorry for the problems you're having with your broadband speed during peak times.  It does sound like congestion.  What exchange are you connected to and I will check for any known issues?  I may need your details to know for sure but let me know the exchange you're connected to and we'll take it from there.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Distinguished Guru
Distinguished Guru
Message 6 of 10
Err @RobbieMac Hastings as per DSL checker in OP.Smiley Very Happy
Moderator
Moderator
Message 7 of 10
Oh dear, I blame the early hours of the morning.  How I didn't see that!! Smiley LOL
@Gabloe Nothing obvious stands out whilst checking this.  I'll need your details to know for sure.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you.
Cheers,
Robbie
Kudos”
Gabloe
Message 8 of 10
Thanks. I've responded to the PM.
Porterballs
Message 9 of 10
Hello I'm also in hastings! Had a engineer out this morning but he cant find any fault in the line! Its apparently on bts end, i have congested inconsistent speed since Thursday and seen no improvement! Was also up graded to fibre superfast 2 so haven't seen any benefit from that yet! I hope bt let us know what's going on as like I said the engineer cant solve the issue, he mentioned bt wholesale and problems further up north, and several of hes friends in hastings are experiencing the same issues
Moderator
Moderator
Message 10 of 10
Hi @Porterballs
Thanks for posting and welcome to the Community.
Sorry that you're also having this problem.  You may also be connected to the same SVLAN as @Gabloe but we can check that out from here.
Cheers,
Robbie
Kudos”
