Danniey
Message 1 of 12
Powerline Extender Speed Slows Down After 5 Minutes
Hi,
I have a pair of BT Broadband Extender 600s which have work perfectly when I am at my house, speeds of 40mb down which is what the wifi signal gives too, however I am at my fathers house for a fortnight and when I plug the extenders in I get a speed of 60mbs which holds for a few minutes then it drops to less than 10mb. I've moved plug sockets, replaced ethernet cables on both ends, disconnected every other linked device, and relinked the pair and every time I unplug and replug the speed shoots up to 60mb (which is what the wifi connection is!) and then after 5 minutes drops to less than 10mb.
I took them back home yesterday to double check it wasn't the extenders and they were working as normal with no issues, so I'm wondering what the issue is here, is the speed getting throttled? The fact that it shows a 60mb connection but then drops instantly drops is incredibly frustrating!
11 REPLIES 11
imjolly
Message 2 of 12
Re: Powerline Extender Speed Slows Down After 5 Minutes
your speed is not being throttled as you say
could simply be the electrical wiring in your father's home is not as good as that in your home
Danniey
Message 3 of 12
I'm just curious why it shows such a high speed when it's plugged in for it to drop, surely any issue would be immediately present upon plugging it in?
gg30340
Message 4 of 12
If your father's Internet connection was being throttled it would happen all the time not just when you plugged in Powerline adaptors.
As has been said, it could be poor wiring however you should check that your father has turned off "smart setup" on the Homehub. It can cause problems with some devices.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
imjolly
Message 5 of 12
it could be that on connection you get speed expected but signal encounters the poor electrical cable it has to drop speed to maintain a connection.  just suggestion and one thing for sure there is a problem and it does not seem to be the adapters
Keith_Beddoe
Message 6 of 12
Is your father also a BT Broadband customer using a BT Home Hub?
You need to also see if the speed drops on the Ethernet ports of the hotspot 600, to see if its just a wireless issue.
Danniey
Message 7 of 12
I switched off Smart Setup unfortunately to no change, and yes both my father and I are BT Infinity users.
Keith_Beddoe
Message 8 of 12
Try the Ethernet ports, as it could be that the wireless channel that the hotspots are using, are very congested.
You can login to the hotspot and change the wireless channel
Danniey
Message 9 of 12
I'm using the Wired Broadband Extenders, not using the Wifi signal at all.
Keith_Beddoe
Message 10 of 12
