liamg91
Message 1 of 6
Problem with upgrading to Ultrafast fibre 2
Hi guys
I currently have Superfast fibre 4 unlimited and have fibre to the premises (FTTP) installed in my house. I am wanting to upgrade to Ultrafast fibre 2. It says on the landline and postcode tracker for my house number that if i was a new customer i could buy Ultrafast fibre 2 straight away, but if i go to upgrade it doesnt give me the option. Ive also rang bt and on their computer systems at the call centre say i cant upgrade either but if i was a new customer i can order it. Could you guys shed any light on this.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Problem with upgrading to Ultrafast fibre 2
did you phone the dedicated FTTP team on 08005874787
liamg91
Message 3 of 6
Hi
Yes, they said exactly the same thing. I just dont understand. I asked if i could end my contract and start a new one on ultrafast fibre 2 but they said i would incur charges and im not doing that. At a bit of a dead end.
Rdan
Message 4 of 6
I had the same problem. Then the other day tried to do an upgrade and still had the issue. Opened another tab and did a post code check which showed that i could get ultrafast 2. Then went back to the tab with the upgrade option and it worked. I now have ultrafast 2 upgraded from superfast 4.
Rdan
Message 5 of 6
I had the same probmem. Then about a week ago tried again online. Still had the issue but when i opened a new tab and did a post code check as a new customer it again showed that i could get ultrafast 2. Went back to the upgrade tab and it worked.... upgraded from superfast 4 to ultrafast 2.
liamg91
Message 6 of 6
Thanks.
That didnt work, but i got through to someone who knew what they were doing today and they accessed a back office secondary system......and it worked! Only took 5 months.
