Message 1 of 11
Problems online gaming
Hi, I joined BT over 2 years ago as it was the best option for myself and my partner who are gamers. We each have a ps5 and other devices. We noticed at first even though the speeds are great, one of us would get kicked out of online sessions if we were in the same one together. The ping spikes are crazy high too. I called bt and spoke to a lovely gentlemen who did something to make sure our connections were so much better. Problem is now we had to get a replacement router and the settings are back to square one. I called bt the other day and the guy said he couldnt get the notes from the previous call as it was over 2 years ago so he would clear the channel and reset the network, however this has actually made things worse. The connections are terrible and the ping spikes are high again. He told me to come on here to get some answers as he said he could do no more over the phone. Has anyone else gone through this and if so what do we do to resolve this?
thank you so much 🙂
10 REPLIES 10
Message 2 of 11
Re: Problems online gaming
The only settings you can change on the BT hub are to change WiFi channels and you can do that yourself.
However, using WiFi for gaming rather than a wired connection is never going to be ideal.
Message 3 of 11
I totally hear you, however problem is im in a new build property and the hub has to be placed in a cupboard. thing is though whatever that bt guy did over the phone worked perfectly but i just dont know what it was. we've been told to move the hub but i cant as the ont box is in the cupboard and im not allowed to drill through the walls
Message 4 of 11
As stated, the ONLY thing the guy could do would be to change WiFi channels.
Go to advanced wireless in the hub manager and experiment with different channels.
Message 5 of 11
we've done all that its still not working properly so thats why i called and the guy on the phone told me to come on here
Message 6 of 11
There are no other settings you can change.
You could try depowering the ONT for half an hour or so to give the hub a different IP address when it reconnects. This might give a different routing to your game server.
Message 7 of 11
Hi, obviously I can’t see your setup so it’s a little hard to envisage. You say your router is in a cupboard with the ONT? I assume therefore that the power supply for both is in that cupboard and that the Cat5/6 lead from the ONT is plugged directly into the router instead of a wall socket?
Would it be possible to move the router by drilling through the top or bottom of the cupboard frame and running the router power lead and an extension Cat5/6 lead through trunking to a location outside the cupboard itself?
Fully appreciating that the ISP has limited options for the adjustment of settings, finances permitting, a third party router that you can adjust settings might be more suitable? I can for instance prioritise certain devices over others on my network with my own setup.
How many other devices do you currently have connected to your router on a routine basis?
Message 8 of 11
Yeah thats exactly how its set up. I am unable to drill any holes or move the router at all ive spoken with my landlord about this and its a definite no.
We've split all the devices so the consoles are running on 5ghz and everything else such as tablets, phones and the sky q box are all on 2.4.
i was downloading a movie last night and my game lost connection completely. All this seems to be happening ever since we got our router replaced
Message 9 of 11
@shyneecie
Yes, somewhat inconvenient for you that it's the landlords rules and you're stuck with the location situation.
I tend to harp on a bit about 3rd party routers, I'm no fan at all of ISP routers purely because of the lack of flexibility to change settings. The plus of a WiFi 6 (802.11ax) router, is that depending on the router brand, it may well support OFDMA and QoS (you can search for the book definitions) both of which might significantly improve your connection issues. You can also change DNS server settings within the router itself, MTU (Maximum Transmission Unit) settings. You can even change the channel width settings for 2.4ghz to between 20 and 40mhz. I know it probably comes across as a bit gobbledegook, but that's half the fun of exploring the equipment for me.
You might I be able to improve the problems using a WiFi extender, but it's no guarantee.
Have you tried a hard reset of the router? That would probably clear the cache but any improvement may be shortlived.
I wish you luck, it's clearly a frustrating experience for you.
Message 10 of 11
As you have SKYQ  it uses channel 36 so you need to change the hub 5ghz channel to something else like 44 or 48
