Message 11 of 17
Re: Process for moving to a brand new cabinet that has been located in our village?
Someone will know, but likely not anyone who is customer facing.
Message 12 of 17
Hi you've got no chance of being put on new cabinet ive got same problem i get speeds of 2.5 if I'm lucky cause we are over 3500 metres from cabinet all the other properties in the village get fibre from cabinet but i live down a long straight a new cabinet cabinet has been installed just round the corner where there are about a dozen house's that is only 400 metres from our property  contractors installed new armoured cable through ducting outside our drive the cabinet been up and running for over 18 months I've phone sky about being moved to new cabinet and been told they can only raise falts with openreach sky said cancel service and reorder and they can request a survey to be put on the new cabinet I've cancelled service and now they said it can't be done you can't speak to openreach as there's no customer service I've sent many emails to openreach they say there's no fibre in our area I've emailed stated a new cabinet has been installed they've emailed back saying it can't be done as properties are served by there own underground duct there is only two man holes to new cabinet an engineer even traced a pair of wire's to new cabinet I've emailed openreach stated this and they say there's no fibre in our area and get together with your neighbours for fibre partnership scheme my neighbours have fibre and get 80mb from new cabinet I've emailed back stating this but openreach ignore my emails it's so frustrating I'm the only property who can't get fibre in our area I've given up now and brought a ee 4g home router and antenna kit and get speeds of 30 to 50 hope you have better luck than me
Message 13 of 17
You are posting on a two year old thread and the OP has not been back to the forum since the last post so you may not get a reply.
Message 14 of 17
Hi,
Your situation is almost identical to ours but we only get 1mb. Our neighbours get 80mb. Wouldnt mind but they are geriatric and think netflix is something done with your fingers and curtains. How is the wireless router working out? Is there a lag? It seems to be our only option, OR and BT dont care. They say do a community programme but since we are the only ones with poor speed thats about as likely as being able to stream a programme or do a video call
Message 15 of 17
Hi Ronnie
I've brought a ee 4g home router that was better than broadband but still not a stable connection ive got 3 teenagers and it was no good for gaming what ive done now is brought a 4g antenna which has made a big difference stable connection ive also switched from o2 to ee with mobile phones so i can gift data i did look into satellite broadband but was out of range hope this helps
Expert
Message 16 of 17
@Ronnie82wrote:
Hi,
As stated above you have posted on a very old thread so are unlikely to get a response from the OP.
The OP was discussing possible cabinet moves as a likelly result of an infill all-in-one cabinet.
Have you contacted your local BDUK scheme to see if there any plans that maybe beneficial to you ?
Message 17 of 17
He has his own thread running
https://community.bt.com/t5/BT-Fibre-broadband/Cabinet-change/m-p/1964856#M292188
so it would be best to stick to the one thread and not continue on this old thread.
