nino
Message 1 of 6
Profile reset needed or just some patience?
Our landline and infinity connection was enabled over a month ago.  We were out of the property for 2 years and prior to moving out we achieved 40MB+ speeds.  Since we moved back in the homehub was reporting ~20MB.  I put this down to contention ratio on the line or something of the sort.
A few days ago i noticed our landline wasn't working, we never use the thing and only have it for the broadband.
I logged a fault and an engineer came out, he said our connection was a mess.  It took him ages to find our "jumpers" ,the "D line" wasnt connected and we were likely connected to the "wrong broandband package" and we should be in a "40/10 circuit".   He also requested a new line test, I may have some of that information a little off.
Given the line was activated a month ago should I request that the profile should be reset for the line to be retrained?
Here is some of our connection information:
Thanks!
5 REPLIES 5
imjolly
Message 2 of 6
Re: Profile reset needed or just some patience?
Your connection speed is 22mb and right at bottom of your estimated range so BT are not going to help
which exchange and cab are you on?
nino
Message 3 of 6
Carterton exchange and Cab 20
imjolly
Message 4 of 6
Unfortunately you are in an ECI cabinet and therefore will not get a speed boost from G.INP
your connection speed is virtually same as max attainable speed so I f using test socket with filter then looks like as fast as line can handle
nino
Message 5 of 6
The chap fitted a new master socket and I’m plugged directly into that.
Annoyingly we got +40 a few years ago, we moved out of the country and rented the house out so the line has been reconnected a few times, what are the chances we are connected to a different cab? Or is it just. Case of more people in the area so the service has gone down?
nino
Message 6 of 6
Used the BT webchat to query the speed and a few line resets later im getting:
 Downstream sync speed:
32.04 Mbps
 Upstream sync speed:
7.87 Mbps
Hopefully that goes up over time
