Swelsh79
Newbie
Message 1 of 14
Purple light flashing on smart hub
Hi I am posting on behalf of my parents who have very recently subscribed to bt fibre broadband from normal broadband. Ever since it was activated on 31 dec the smart hub flashes purple with occasional periods of it operating properly.
They have had to date one new router and an engineer visit to the home and he confirmed their is no issue with the line in the house. So they received a new router as they were told no issue could be found outside the property. I have read several posts here with pretty much the same issue but it now feels like they are getting no where fast. The engineers are adamant there is no issue with line in the property or outside it. So I fail to believe that a second faulty hub has been received.
Comments and advice greatly appreciated please.
13 REPLIES 13
Message 2 of 14
Re: Purple light flashing on smart hub
Welcome to this user forum.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Swelsh79
Newbie
Message 3 of 14
There was but this was reported and cleared prior to the first engineer visit. The line is silent now. Every time they run a test the broadband connects as it should then maybe an hour later it drops again.
Message 4 of 14
did you turn off smart setup?
can you post some stats  advanced settings then technical log information
do you have a filtered master socket and connecting hub direct to master - no telephone extension wiring used?
Message 5 of 14
There is probably an intermittent high resistance fault.
What does your master phone socket look like?
Master socket with one socket
Or
Master socket with two sockets
Swelsh79
Newbie
Message 6 of 14
I will when I get home tonight. The engineer installed a new master socket to rule that out, no extensions are connected. Not sure if my dad turned off smart set up. Would that make a difference ?
Message 7 of 14
smart setup can cause problems and best turned off   just wish BT would delete from hub
Swelsh79
Newbie
Message 8 of 14
Socket is the one bottom right, open reach with curved top.
Swelsh79
Newbie
Message 9 of 14
Engineer is currently there now and doesn’t know what’s wrong and is currently up the pole in the back garden.
Message 10 of 14
That is the new one,
What I would suggest that you try, just  to eliminate a possible faulty socket, is to unclip the front section and try the test socket. Plug the microfilter into there, leave it for a couple of days to see if you still get the flashing purple light and disconnections.
