Message 31 of 32
Re: BT can't be bothered to reconnect me
@BrendanHickey wrote:
Okay my internet is working now.
So a factory reset sorted it out?
That is all it probably needed as the line was interrupted.
If so, you need to cancel the visit.
BrendanHickey
Message 32 of 32
They probably would have done it when I was on the phone with them
