BrendanHickey
Message 21 of 32
Re: BT can't be bothered to reconnect me
I phoned the open reach number and did a ring back test and it worked fine and is a clear line
Message 22 of 32
@BrendanHickey wrote:
I just got hold of a phone and it's working fine
Have you checked the number is correct, as I posted on my last post? The ringback test does not prove this.
BrendanHickey
Message 23 of 32
Just did a quiet line test and No noise,
Message 24 of 32
You still haven't confirmed it gave your correct number, which is crucial.
BrendanHickey
Message 25 of 32
Yeah the phone number was correct
Message 26 of 32
Which BT home hub do you have?
BrendanHickey
Message 27 of 32
2, I have just spoken to live chat and they ran test and said the fault is outside the property and someone is scheduled to fix it on Sunday
Distinguished Guru
Distinguished Guru
Message 28 of 32
You have a hub 2???
There will be no-one fixing anything on Sunday or Monday. Earlist would be Tuesday.
Message 29 of 32
A broadband fault is something the line test cannot show.
Is it the new BT Smart Hub 2 that you have?
BT Smart Hub 2
Please try the following.
factory reset the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
If you still do not get a connection, then
What does your master phone socket look like?
Master socket with one socket
Or
Master socket with two sockets
BrendanHickey
Message 30 of 32
Okay my internet is working now.
