Message 1 of 2
Question about full fibre installation
The full fibre broadband is now available in my area.  I've heard that they usually install it at the front of the property. I'm just wondering whether they can install it in my room at the back of my house.  My PC is located there and I previously requested to move the master socket in that room since I'm using LAN cable on my PC.  Thanks to anyone who will answer my question.
1 REPLY 1
Message 2 of 2
Re: Question about full fibre installation
That would be up to the install engineer. They usually try to install where you want it but there may be valid reasons why it can't be done.
