andycthomas
Newbie
Message 1 of 2
Question about upgrade to Superfast Fibre Plus
Hello,
We are due to have our broadband upgraded to Superfast Fibre Plus on September 5th. The new smart router has arrived at our house. When should we switch over to using the new router, and how will we know when the new service is active.
Thank you
Andy
1 REPLY 1
Message 2 of 2
Re: Question about upgrade to Superfast Fibre Plus
if you already have fibre connection then you can use your new hub straight away  even if on adsl the new hub should work  plug and play
