Sage
Sage
Message 11 of 14
Re: Question on FTTP performance testing
If you mean the test via the hub there's a lot of FTTP users having issues with it.
tarbat
Message 12 of 14
Thank you. So if presumably BT know this, why do they insist on sending an Openreach engineer out to fix it? What a waste of my time 😞
tarbat
Message 13 of 14
darthmuppet
Message 14 of 14
ok, engineer did not come, because for some reason the booking did not make it to the engineers system (whatever that means). i called in to rearrange, to be told that I don't need an engineer, and that my performance is fine when they connect to my hub. I'm leaving it at that, I was just following the guidance. I don't use the SH as a router, so the fact that B's test doesn't work isn't really a hindrance to me, just a disappointment.
