imjolly
Message 11 of 14
Re: Quick question regarding, Network up time and System up time.
if there is a chnage in the network/dsl uptime then your router has reset at that time  the system uptime will only change when you disconnect the power from the hub or a factory reset
JackGJones
Message 12 of 14
So by saying that then the issue i had with my internet constant drops Has not been fixed then if my dsl uptime dropped again after just 2 days of being "fixed" ?
imjolly
Message 13 of 14
if it is constantly dropping then there may be a problem
are you using test socket with a filter even if you have a filtered maste socket as that will eliminate your internal wiring as being a problem
try quiet line test from test socket  dial 17070 option 2  should be quiet and best with corded phone
JackGJones
Message 14 of 14
Done all of that made no difference before i just had a thread with about 40 posts an mod help had a engineer sent out they thought they fixed it. Case was closed ill monitor it from now on but the fact my dsl dropped again after 2 days uptime shows there is a issue still.
