Mixer
Message 11 of 13
Re: Quick queston
I have no problems with my connection its bang on 76.9Mbps when converted Smiley Very Happy
The 125Mbps i got on a 321Mbps connection, sure. BT wholesale connection tester is not accurate, like i said overwhelmed, I wouldn't be surprised if the routes or even hops to that speedtest are failing or broken, my opinion
BT doesn't have control of most things, fact.
I'm off the pick my other half up, have a good day all. Smiley Wink
Guru
Message 12 of 13
Re: Quick queston
BT Wholsale has control of everything ... and as far as speed tests go the BT Speedtest is the only test that actually runs within the BT Network boundary layer, and thus is NOT affected by alternative and ever changing internet traffic. 😉
Mixer
Message 13 of 13
Re: Quick queston
That may be true. I'm not 100% BT WholeSale connection test accurate enough, it may find real faults, thats it.
BT WholeSale must have some laggy hops for sure, we're getting 12ms French gaming server, 15ms Dutch. Out of country servers would be severely affected by Internet traffic and distance, especially gaming servers. What am i missing here?
After multiple speed and ping tests, BT wholesale results are behide in all cases, i just don't trust it, thats all. I don't have any problems, only with BT Wholesale. Smiley Surprised
