Message 1 of 3
Re: Activation - smart hub flashing purple ?
How can this be the solution??????
Hi, did you get anywhere with this issue?
What was the solution?
I'm having the same issue. Purple Flashing light.
The line is fine, no noise, all working ok.
Got the new faceplate, all testing fine with the phone.
Did reset the modem. did switch off the smart settings thing.
And still getting the purple light.
2 REPLIES 2
licquorice
Message 2 of 3
I've moved you to your own thread as you were posting on a 2 year old thread.
If the light still flashes purple when the hub is connected to the test socket behind the removable faceplate of the master with a new filter, you need to report the fault to 150.
All your duplicate posts on other threads have been deleted, please do not make multiple posts regarding the same topic.
imjolly
Message 3 of 3
Re: BT can't be bothered to reconnect me
please stop posting the same thing on different threads
is this a new connection and you are waiting for activation?  if so when was your activation date
