GHO5T
Message 1 of 3
Re: BT Home Hub 5 frequently disconnects (regret infinity so far)
Yeah iv just took out bt infinity 2 even though my line can only handle 50mbps im still getting charged for 76mbps iv had nothing but trouble since ive joined from sky fibre which to be honest was a far better service my connection has been dropping out quite frequently with my s6 my tablet my daughters iphone an tryin to play my ps4 online has become so stressful i also get ip fragmentation warnings from my ps4 when doin network speed tests iv tried all of the trouble shooting guides but no luck now im dreading the dreaded customer service phone calls where i know i will get nowhere wish i had stayed with sky and it was cheaper 😥
2 REPLIES 2
Message 2 of 3
if your line can only handle 50mb then what made you go for infinity 2 when you barely get more than previous infinity 1 package.  I would phone options team and downgrade to new infinity 1 package of 55/10mb and get same speed cheaper
options team are uk based  0800800030
Message 3 of 3
to help with your disconnecting problem can you
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
 are you using test socket with a new filter
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
