Uday123
Newbie
Message 1 of 2
Re: BT Infinity 2 installed but slow speeds
I have had bt infinity 2 for a week now and these are the speeds im getting:
Download: 28.76mbps
Upload: 7.56bmbps
Ping: 41.99
1 REPLY 1
Moderator
Moderator
Message 2 of 2
@Uday123 Please can you post your router stats and we'll take a look.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
