Message 1 of 47
Re: BT Super Fast Fibre Plus not reaching the average speed
BT told me i can expect 80. I have seen 71 regularly, I now have 47. Friday sees them 'doing the cabinet' There had better be an improvement...................
46 REPLIES 46
Message 2 of 47
I have moved your post to start a new thread as it is just muddying the waters of the original thread.
Message 3 of 47
Message 4 of 47
So, the engineer checked my end on Wednesday said I should have 80 but was getting 39/42.  Raised a fault and booked another engineer for the cabinet fault to be fixed today.  Engineer visit complete according to the fault tracker.......and...
I have 15 mb/s now..................................
Oh, BT..........
Sage
Message 5 of 47
Can we have some hub stats from you to see if we can spot what is going on.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
Are your speeds via wired or wireless connection?
Message 6 of 47
Wired ethernet.
I have had 71.
New contract a month ago and 42
Engineer test in master test socket 37
Engineer visit to cabinet today............ 19
PANTS!
Product name:
BT Hub 6A
Serial number:
+084319+**************
Firmware version:
SG4B1000B540
Firmware updated:
21-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 9 Hours 47 Minutes 9 Seconds
Data rate:
17.00 Mbps / 49.00 Mbps
Maximum data rate:
21417 / 60417
Noise margin:
9.1 dB / 5.6 dB
Line attenuation:
15.9 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
499 MB Uploaded / 5652 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
Software variant:
Boot loader:
7.33.1
Allegedley the fault is still being attended to according to Fault tracking but it also says that engineer visit is complet.  Does this mean that the cabinet is not the fault and that it could be the exchange/line etc?
Thanks for the help
Message 7 of 47
The plot thickens...................................................
BT Wholesale Speed Test now reads 43.62.
Interesting that their Diagnostics software on my line states that 43 is pretty good as max. achievable speed on  my line is 47.43 !.................................
Very interesting conversation coming up with BT with regard to misselling, misrepresentation, overcharging, misleading the public and dare I say the word Fraud? with regard to my recently expired contract.....................
I feel used and foolish if all this transpires to be true and I shall certainly not go quietly.
A very unhappy Bennachie
Message 8 of 47
As can be seen from your screenshot, your current sync speed is 49M with a possibility of attaining 60M. Your speed has probably been reduced by DLM due to previous line instability. Given time your speed should increase. What speed wre you guaranteed in your contract email?
Message 9 of 47
80 with average 67................... Joke!
i thought I had seen 71.  As this is all new to me I could have been mistaken
Message 10 of 47
After more phone calls this am I am assured that my line is capable of 80mb/s and that there is a fault - its just that they don't know what it is..........................they are looking into it and the case has been escalated and I now have a dedicated case manager who will contact me within 24 hours......................Hmmmm
Speed resolutely stuck at 43.5 mb/s and max line speed says 49 mb/s.  BT faults assure me that the line speed reading is erroneous because of the fault and that I shoud be getting a minimum of 57mb/s (which is a long way short of the 80 it was suggested I get and causes some maths headaches with an average of 67...............which suggests 80 quite often.
IF the line only suppots 47, why have they sold me superfast infinity 1 at 50mb/s minimum for the last 18 months and just sold me Superfast Plus with 67 average less than a month ago?
I suggested that this should be investigated and that I should get what I pay for, nothing less, and if that cannot be delivered then there should be a commensurate reduction in tarrif............................ reply we'll look into the fault and get back to you............
