barneyhairball
Message 1 of 3
Re: BT smart hub and infinity
I'm lost. I set up new smart hub today. Do I need to plug it into the open reach socket on the wall or can I plug it into any phone socket? Open reach socket is in a cupboard and therefore very slow. Please help.
2 REPLIES 2
smf22
Recognised Expert
Message 2 of 3
@barneyhairball
This thread is discussing an Openreach modem (shown below) which is completely different to the Openreach socket.
The Smart Hub uses the grey "Broadband" connector on the rear of the unit to connect directly to a telephone socket in your house. You'll very likely get a better connection if you can connect directly to the master socket.
The type of socket you have can be found on the page What type of master socket have I got?
Regards
Distinguished Guru
Message 3 of 3
If the Openreach socket is a filtered one - in other words if it has two sockets on the front, one for phone and one for broadband - then you need to use that socket.
If the master socket is just a standard single phone socket, then you can use a microfilter in any phone socket, and use that.  But you might get a slower connection if you don't use the master.
