petecov44
Message 1 of 10
Re: Broadband FTTC/P Availability
Well I want to know how to get 330/30 FTTP. I can afford install and the monthly cost ( up to £500 a month) but I can't get anyone to tell me how to order it. I am on Newport Savoy exchange which the checker says is enabled for it. I am 240M away from the exchange
9 REPLIES 9
shirts
Recognised Expert
Message 2 of 10
According to http://www.samknows.com/broadband/exchange/SWNE_EX FTTP is not available on this exchange......
Please enter your phone number at http://www.dslchecker.bt.com/adsl/adslchecker.welcome and after deleting your telephone number, post the results.
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
petecov44
Message 3 of 10
yes.. because I am stupid enough not to check first before coming here! (can you feel the sarcasm!?)
Well it says it is.. so either it's lying or BT is.
BT BROADBAND AVAILABILITY CHECKER
Address  Exchange NEWPORT SAVOY is served by Cabinet 89
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)79.659.92019.6--Available
FTTC Range B (Impacted)70.341.32013.9--Available
WBC ADSL 2+Up to 17--10 to 19.5Available
WBC ADSL 2+ Annex MUp to 17Up to 1.510 to 19.5Available
ADSL MaxUp to 7.5--6.5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
FTTP on Demand33030--Available
Fibre Multicast------Available
Copper Multicast------Available
Message 4 of 10
What is available is Fibre to the Premises on Demand (FTTP on D) this is a different product from Fibre to the Premises (FTTP). As far as I am aware no ISP is offering FTTP on D even although it is available at some exchanges.
Guru
Guru
Message 5 of 10
petecov44,
There are a few ISPs who are offering FTTPoD (Fibre to the Premisies on Demand), try calling the BT Retail's FTTP department on 0800 587 4787 and see if they will offer you FTTPoD (probably needs a site survey to get estimated install costs)
Here's Openreach's estimated price list to ISPs. http://www.openreach.co.uk/orpg/home/products/pricing/loadProductPriceDetails.do?data=0WyIM7tTGGgucF...
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
shirts
Recognised Expert
Message 6 of 10
@jac_95
Are those the charges made to the isp ?
Guru
Guru
Message 7 of 10
shirts,
Yes these are the approx. charges Openreach bill to to the ISP/CP. The end users cost may be slightly higher as the ISP/CP may add charges, for example product/services charges.
Try a Search
shirts
Recognised Expert
Message 8 of 10
Ouch......
shirts
Recognised Expert
Message 9 of 10
The phrase "should've gone to Specsavers" comes to mind...........
Guru
Guru
Message 10 of 10
Please keep it friendly.
petecov44 let us know how you get on 🙂
Cheers
Try a Search
