We have been having a similar problem, but the signal loss lasts just a second then reboots. No faults can be found at our end or in the line. It's been happening for several weeks now and sometimes occurs several times a day and other times we can go a few days okay.
Solved! Go to Solution.
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
can you post stats from router if hh6 then advanced settings then technical log information
check for line noise dial 17070 option 2 should be silent and best with corded phone
does your hub light assuming you have hub change colour when connection drops? are you using wifi?
My intermittant loss of signal problem has, after several months of tests and trying things, at last been solved by replacing the router with a newer model.
