Magallenic
Message 1 of 4
Re: Broadband disconnects every couple of days
We have been having a similar problem, but the signal loss lasts just a second then reboots. No faults can be found at our end or in the line. It's been happening for several weeks now and sometimes occurs several times a day and other times we can go a few days okay.
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
imjolly
Message 3 of 4
can you post stats from router if hh6 then advanced settings then technical log information
check for line noise   dial 17070 option 2  should be silent and best with corded phone
does your hub light assuming you have hub change colour when connection drops?  are you using wifi?
Magallenic
Message 4 of 4
My intermittant loss of signal problem has, after several months of tests and trying things, at last been solved by replacing the router with a newer model.
