fatty28uk
Newbie
Message 1 of 4
Re: Connection dropping at regular 7 minute intervals
Seems this is an old issue, going by the dates on here, but I can assure you that this is still a problem for us, and has been for a good while.
After goodness knows how many maddening calls to Indian call centres that offer only the same inane drivel dressed up as advice each and every time, new cables, junction boxes, 3 routers and now our own router, countless visits from "engineers" who have little knowledge of what they are doing, and one nice chap who tried harder than most and even got the cable in the road dug up, this problem, still persists.
It makes me laugh to watch the TV adverts that offer super reliable BT Broadband at lightening fast speeds, at a discount too. I have to laugh otherwise I might cry. We are paying for an Infinity service, but have never received the promised speed or reliability. We have been informed that our line speed will never take Infinity speeds and the only way to stop this incessant 7 minute drop out is to have our speed dropped accordingly. Ok fair enough perhaps, but why do we still have to pay for something we cannot receive, and why after having the speed lowered, does some idiot then turn it back up again at a later date only for the drop out/calls to Indian call centres/inane advice/blah blah cycle to begin again? Is there no inter departmental communication. How ironic that would be. And is there no way to get our ludicrous billing reduced to match the line speed that does work for us?
Dennis
3 REPLIES 3
Message 2 of 4
I moved your post from the adsl board as you are an infinity user and also thread was 5 yrs old
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
 are you using the test socket with a new filter
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
is there anything here that could cause the problem
interference causes
Message 3 of 4
If it's happening every 7 minutes I would be looking into the possibility of REIN
Moderator
Moderator
Message 4 of 4
Hi @fatty28uk and welcome.
I'm sorry you're having problems with the connection but the symptoms you're describing would point to a REIN issue (spot on there @Webby).
Take a look at Repetitive Electrical Impulse Noise (REIN) for help with identifying the possible cause and let us know how you get on.
Cheers
David
