stoatsngroats
Message 1 of 4
Re: Connection dropping out constantly
Thanks PaddyB, I have responded!
SnG
3 REPLIES 3
stoatsngroats
Message 2 of 4
Had an engineer call today, and made some physical changes to corroded outside box, which appears to have made some difference as we have had no issues this evening.
follow call from Neilo to advise that he has read the techs report and will check back with me next week to see how the broadband works.
Thanks to everyone for their help with this issue.
hope that you have had a similar result Bobbydigital.
sng
Moderator
Moderator
Message 3 of 4
@stoatsngroats Thanks for speaking with me this evening, I'm really glad your connection is back up and running after the engineer visit. If you need any help in the future post back and we'll be happy to help. Smiley Happy
stoatsngroats
Message 4 of 4
Re: Connection dropping out constantly. Resolved!
Thanks NeilO, for helping sort our connection, which has been fine fir the last week achieving some great speeds. Please pass my thanks to the team there, and to you personally for your informative and reliable support, it’s much appreciated 👍👍
sng
