Message 1 of 90
Re: Download speed has been reduced
This is so familiar, a month of Openreach visits, used to have 43Mbs now after 3 days of engineering visits it’s down to 20 at best, lots of wiring replacement between house and BT manhole etc but still the same .
we’ve had 4 visits this month!!
A bit of honesty required by BT
89 REPLIES 89
Message 2 of 90
I moved you post to start your own thread so any replies will be about your problem and not confused with the other post which is about a year old
Anyway welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 90
Exchange SIDMOUTH is served by Cabinet 4
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean) Ianf3_0-1605357354531.gif
46.332.48.16.126.7AvailableAvailable--
45.127.485.820AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 10.5--9 to 12AvailableAvailable--
Up to 10.5Up to 19 to 12AvailableAvailable--
Up to 6.5--5.5 to 7.5AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
33.43
6.07
2020-11-06
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
02-11-2020
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
The premise/line is associated with exchange which is NOT part of current fibre priority programme.
The premise/line is associated with exchange where WLR is not withdrawn.
The premise/line is associated with exchange where SOADSL service is restricted.
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Comm
Message 4 of 90
Currently getting 18Mb down and 4.6 up
Sage
Message 5 of 90
Rest of info?
Message 6 of 90
This is in the logs
:A device reset was performed. Reason SAAF(5)
Message 7 of 90
Do you want the whole log?
Message 8 of 90
BT Hub 6A
Serial number:
+084319+NQ62647650
Firmware version:
SG4B1000E040
Firmware updated:
28-Oct-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 10 Hours 43 Minutes 29 Seconds
Data rate:
4.91 Mbps / 18.00 Mbps
Maximum data rate:
4933 / 37628
Noise margin:
6.3 dB / 14.6 dB
Line attenuation:
70.6 dB
Signal attenuation:
50.7 dB / 46 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
370 MB Uploaded / 1 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
PALMBOON
2.4 GHz wireless channel:
Channel 11
5 GHz wireless network name:
PALMBOON
5 GHz wireless channel:
Channel 40
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
40:C7:29:05:CC:AF
Software variant:
Boot loader:
7.33.1
Message 9 of 90
Log is way too big to send as txt,
Sage
Message 10 of 90
Don't want the log. Quiet line test? 17070 option 2.
