izzyazz
Message 11 of 19
Re: Incorrect Information on Database?
Thanks for the phone call and quick response to this - hopefully the database will be corrected now.
Moderator
Moderator
Message 12 of 19
Hi @izzyazz Sorry that the request to update the address records has not been completed yet. I have escalated this with Openreach and should hopefully completed early next week.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
izzyazz
Message 13 of 19
Thanks - I was wondering how I could find out whether the database was correct now.
Message 14 of 19
@izzyazz the mod post yesterday said they hoped be fixed early next week - maybe wait
izzyazz
Message 15 of 19
Sorry - my clumsily expressed message was meant to show that I had been wondering about the database and was now grateful that the moderator was keeping me updated, not that I thought it would be fixed instantly.
Moderator
Moderator
Message 16 of 19
hi @izzyazz Just to keep you updated I've had to raise a case to get the records manually updated as the robotic process has got stuck. This normally takes 3 working days and I'll check and post back to let you know when this is completed.
Cheers
John
Kudos”Kudos”
izzyazz
Message 17 of 19
Thank you - very grateful for your time on this.
Moderator
Moderator
Message 18 of 19
Hi @izzyazz I've received confirmation from Openreach now that your address records have been corrected.
Cheers
John
Kudos”Kudos”
izzyazz
Message 19 of 19
That's great - thank you very much.
