Message 1 of 4
Re: Incredibly slow speeds at random times
Just checked my line and these are results Checked with several reputable sped checkers and all are giving me 2 meg down and 0.9 up. What is going on? I used to get 50 and 10 not long ago. BT Wholesale BT BROADBAND AVAILABILITY CHECKER Telephone Number 0 on Exchange SCUNTHORPE is served by Cabinet 65 Featured Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Handback Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper High Low High Low VDSL Range A (Clean) 55 39.8 11.6 7.2 35 Available Available -- VDSL Range B (Impacted) 47.6 31.2 10.1 5.5 25.6 Available Available -- Featured Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps) WBC FTTP Availability Date FTTP on Demand 330 30 -- Available -- -- ADSL Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps) Availability Date Left in Jumper WBC ADSL 2+ Up to 1.5 -- 1 to 3.5 Available -- -- ADSL Max Up to 1 -- 0.75 to 2.5 Available -- -- WBC Fixed Rate 0.5 -- -- Available -- -- Fixed Rate 0.5 -- -- Available -- -- Other Offerings Availability Date VDSL Multicast -- -- -- Available -- -- ADSL Multicast -- -- -- Available -- -- Premise environment Status Bridge Tap N VRI N NTEFaceplate N Last Test Date 06-05-2018 For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage. This line is on a Market B Exchange. For VDSL or G.fast Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions. In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values. Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises. The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Dec-2012; the Formal Retirement date for IPstream is from 30-Jun-2014. If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated. Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check. Note: If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service. Thank you for your interest.
3 REPLIES 3
Message 2 of 4
@buzzapb  are you hijacking someone else thread?
Message 3 of 4
Not hijacking thread. Just trying to find out why infinity 2 is so slow. Just put the info on to help.
Message 4 of 4
can you post stats from your router please
can you run btspeedtester and when first test completes then run diagnostic test and use IE/EDGE not firefox/chrome which have been giving incorrect results  test must be done with ethernet conenction
