PeteB
Message 11 of 16
Re: Infinity 1 Speed Boost given then taken away again???
That’s disappointing!
dittohead
Message 12 of 16
Hope you get it sorted soon.
jonmanley
Message 13 of 16
I also recontracted on the 5th and appear to have lost the boost - had gone from 50 to over 60mb, and now back to just about 50mb.
I have made 3 or so calls, as well, and am getting nowhere!
PeteB
Message 14 of 16
Hi Jon,
Depending on the type of fibre broadband you have installed, you may have posted this is in the wrong forum (as I did earlier!)
If you have FTTP (Fibre To The Premises), then you're in the right thread. But if, like me, you have FTTC (Fibre To The Cabinet) you're not.
However, I'd suggest you check which you have and then start your own thread in this forum so the mods can give you personal support.
imjolly
Message 15 of 16
@PeteB
@jonmanley already has own thread
PeteB
Message 16 of 16
@imjolly
Thanks.
