daryln1243
Message 1 of 14
Re: Infinity service issue?
this **bleep** forum wont let me post a new topic so ill reply to this one with my issue
my speeds not quite were it should be but its pretty stable until! i try to download games through steam ( not sure if any other type of download effects it but steam is were i noticed it)
http://prntscr.com/6rk766  this is my normal connection
http://prntscr.com/6rk7yo  this one is when i resume steam downloads
http://prntscr.com/6rkw9r seen a few posts put this one so ill put it there before it gets asked for
so if anyones got any ideas whats going off here i would love to know.
13 REPLIES 13
Distinguished Guru
Message 2 of 14
Which homehub are you using?
If not, I'll try again 🙂
daryln1243
Message 3 of 14
home hub 5
its only been installed couple of week now
Distinguished Guru
Message 4 of 14
Can you post your helpdesk data from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254 or http://bthomehub.home or http://bthub.home
Please miss out any data you don't want to post
daryln1243
Message 5 of 14
is this right?
http://prntscr.com/6rrxf6
Distinguished Guru
Message 6 of 14
Yes that's it.
It looks like the Steam download is just using up your bandwidth. Isn't that what you expect to happen?
daryln1243
Message 7 of 14
well not really to the point i cant browse the net?
steams only downloading max speed i have had is 2.1mbps
so for it to drop so dramatically no i wouldnt expect that
Distinguished Guru
Message 8 of 14
When you say 2.1mbps, do you really mean 2.1Mega Bytes per second as that is close to the maximum for your line and would saturate your connection.
Message 9 of 14
As regards your download for steam are you possibly mixing up Megabits and Megabytes?
There is often confusion about the difference between a (MB) Megabyte (used for file size) and a (Mb) Megabit (used for download speeds). People often assume that a download speed of 1 Megabit per second (1 Mbps) will allow them to download a 1 Megabyte file in one second. This is not the case, a Megabit is 1/8 as big as a Megabyte, meaning that to download a 1MB file in 1 second you would need a connection of 8Mbps.
I think steam shows it as Megabytes (MB).
This means that if your download of 2.1 is actually Megabytes (MB) your download speed is 16.8 Megabits (Mbps).
daryln1243
Message 10 of 14
it does indeed show at 2.1 MB peak
