brutus66
Message 1 of 13
Re: Introducing Complete Wi-Fi from BT
Hi, the new smart hub 2 is stuck on green light, when i set it up it worked great then it dropped wifi after an hour so i rebooted it and its just stuck on green, no internet so i have had to use my old hub for now. I tried reset button but still stops at green light all cables have been checked and all ok
I contacted customer support by phone but they said im not activted untill the 17th but i have checked the activation email and it says the 12th
So is the hub faulty or was i given the wrong date of activation ?
12 REPLIES 12
Moderator
Moderator
Message 2 of 13
Hi @brutus66,
Do you have any open orders when you log into your MyBT?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
brutus66
Message 3 of 13
only one its for an extra black disk for a blind spot
Moe70
Message 4 of 13
The exchange has to receive the instruction to connect you fully for billing purposes.
brutus66
Message 5 of 13
ok thanks just thought it was strange as i am only changing hubs but with same broudband +
brutus66
Message 6 of 13
brutus66
Message 7 of 13
new smart hub 2 is still stuck on green light
Moe70
Message 8 of 13
Connect the disc to the hub using the yellow cable provided in the box, or use any yellow cable from a laptop. The disc hasn't been registered to the hub yet then.
brutus66
Message 9 of 13
need to get the smart hub 2 past the green light first
Moderator
Moderator
Message 10 of 13
Hi @brutus66
Welcome to the Community and thanks for your posts!
Sorry for the activation problems you're having.  I have sent you a private message with instructions on how you can send us over your details and we'll give you a hand with this. See: Private messages
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
