brutus66
Message 11 of 13
Re: Introducing Complete Wi-Fi from BT
its a faulty smart hub 2 I have another on the way thanks all that helped
brutus66
Message 12 of 13
i can confirm its was a faulty smart hub 2 as the replacement is fully working with no problems
Moderator
Moderator
Message 13 of 13
@brutus66 That's great I'm glad the replacement is working with no problems, thanks for updating the thread to let us know.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
