greenspagbol
Message 1 of 33
Re: Multiple disconnects, wildly changing speeds and attenuation
I've been getting the same problem for the past couple of days - frequent disconnects, drops in speed and the phone line seems clear. I've got a usually solid 25meg connection but now it's in the mid teens, with sometimes a drop to single figures.
32 REPLIES 32
Message 2 of 33
Re: Multiple disconnects, wildly changing speeds and attenuation - 2
@greenspagbol
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
greenspagbol
Message 3 of 33
Thanks very much!
Message 4 of 33
The same questions apply.
Which number matches your master phone master socket?
Single master sockets
Filtered master sockets
Do you have any other phone sockets or extension wiring?
Does your phone line come from a pole, or underground?
greenspagbol
Message 5 of 33
The socket looks like number 6. I had one extension socket, which I've now removed.
The line comes from a pole.
I reset the Smart Hub about 15 minutes ago and things seem back to my normal speed, but I'm not holding my breath. It disconnected around 10 times in the last two hours after being stable all yesterday evening - similar disconnections yesterday afternoon.
Message 6 of 33
if hh6 can you post stats - advanced settings then technical log admin
greenspagbol
Message 7 of 33
Shall I post the information or the event log?
Message 8 of 33
its the admin information not the log
greenspagbol
Message 9 of 33
Is this what you're looking for?
Product name:
BT Hub 6A
Serial number:
+084319+NQ64350515
Firmware version:
SG4B1000B522
Firmware updated:
25-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 21 Minutes 30 Seconds
Data rate:
5.17 Mbps / 27.40 Mbps
Maximum data rate:
5165 / 30413
Noise margin:
5.7 dB / 7.6 dB
Line attenuation:
27.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
4 MB Uploaded / 66 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-GP6Z
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-GP6Z
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:4C:6D:2B
Software variant:
Boot loader:
7.33.1
Message 10 of 33
yes  you currently have 27mb connection with the attainable slightly higher at 30mb  noise margin at 7.6 is slightly higher than normal 6db so if dropped to normal then you may get slightly more speed - but need a stable connection
