greenspagbol
Message 11 of 33
Re: Multiple disconnects, wildly changing speeds and attenuation - 2
Literally just as I got your reply notification I had two hub reboots on the trot and my speed is now 5meg.
greenspagbol
Message 12 of 33
This is what it looks like now.
Product name:
BT Hub 6A
Serial number:
+084319+NQ64350515
Firmware version:
SG4B1000B522
Firmware updated:
25-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 7 Minutes 19 Seconds
Data rate:
548 Kbps / 5.82 Mbps
Maximum data rate:
491 / 5656
Noise margin:
6.7 dB / 5.4 dB
Line attenuation:
37.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
8194 MB Uploaded / 16401 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-GP6Z
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-GP6Z
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:4C:6D:2B
Software variant:
Boot loader:
7.33.1
Message 13 of 33
Where is the home hub connected to at the moment?
Can you connect things up as shown here Infinity - test socket connections
Making sure you remove both parts of the filtered faceplate NTE- all sections
Use the one I have shown as the real test socket.
The attenuation has gon up, so there is a bad connection somewhere.
It could be the faceplate, or the connection block between the incoming dropwire, and the internal cable.
Need to eliminate the filtered faceplate first.
greenspagbol
Message 14 of 33
I don't have a microfilter unfortunately. I'm on Infinity 1 (rural speeds).
Message 15 of 33
BT usually supply two with every home hub. You could try dis-assembing the faceplate, then putting it back together, just in case there is a bad connection between the faceplate and the master socket.
Otherwise, without a microfilter, its not going to be possible to prove the fault.
What you could check, is the connection block between the external and internal cabling, to see if there is any corrosion.
It should be one of these Dropwire to internal connection  or BT 78A
greenspagbol
Message 16 of 33
Managed to find one. 🙂 Here's the latest
Product name:
BT Hub 6A
Serial number:
+084319+NQ64350515
Firmware version:
SG4B1000B522
Firmware updated:
25-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 3 Minutes 42 Seconds
Data rate:
4.33 Mbps / 23.25 Mbps
Maximum data rate:
4327 / 22200
Noise margin:
5.5 dB / 5.4 dB
Line attenuation:
29 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
1 MB Uploaded / 29 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-GP6Z
Smart (Channel 1)
BTHub6-GP6Z
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:4C:6D:2B
Software variant:
Boot loader:
7.33.1
Message 17 of 33
Good Smiley Happy
Can you leave it like that now, and see if it remains stable. Its not unusual for those filtered faceplates to go faulty, as there are a lot of components on it. Rather over engineered in my opinion, for such a simple task.
greenspagbol
Message 18 of 33
Thanks, I've dropped a few meg on my download speed but I'll monitor things and see if they're stable. Weirdly, I had the same problem at around this time yesterday.
Message 19 of 33
While you are waiting, see if you can locate that junction box. Do not touch it for now, as we do not want to confuse the issue.
I have known these junction boxes to be near the front door, and they cause disconnections when someone opens the door.
Usually they are on a wall or window sill (bad place, rather damp).
greenspagbol
Message 20 of 33
It has restarted again a couple of times since, with the microfilter connected. I haven't a clue where my junction box is - never seen one here - and unfortunately I'm disabled and not able to get around too well. Back up again with a 12meg download speed.
