Message 21 of 33
Re: Multiple disconnects, wildly changing speeds and attenuation - 2
I think the only solution is going to be an engineer visit, as its still disconnecting at the test socket.
As you have done the basic checks.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
greenspagbol
Message 22 of 33
Thanks very much Keith, you've been a great help. 🙂
Message 23 of 33
Thanks for your co-operation, I am sure one of the moderators can deal with it from this point.
Moderator
Moderator
Message 24 of 33
Hi @greenspagbol
Thanks for your posts and welcome back!
Sorry for the problems you're having with your broadband.  There is such a massive variation in your speeds when the connection drops.  As the service is still dropping in the test socket it looks like a potential network fault.
Send us over your details and we will take a closer look at your connection from here.  Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
greenspagbol
Message 25 of 33
Sorry to drag this up again, but I wonder if this is weather related?
Connection was fine all afternoon, when it was calm and dry but as soon as the rain came and the wind got up a bit, it kept dropping. My phone line is also now really crackly.
Message 26 of 33
just wait for mods to contact you and they will help - probably engineer visit
greenspagbol
Message 27 of 33
Thanks.
I ended up phoning BT and they're sending an engineer out after seeing problems on the line. Should be fixed by the 29th, fingers crossed.
Message 28 of 33
well if engineer does not turn up you can always get mod help
Moderator
Moderator
Message 29 of 33
@greenspagbol I'm glad to see that you've got an engineer visit arranged, can you post back to let us know how they get on?
Community ModeratorNeilO
Kudos”Kudos”
greenspagbol
Message 30 of 33
Certainly will. Thanks again for everyone's help. 🙂
