antonwelly
Message 1 of 3
Re: New Infinity customer - slower speed than ADSL
hi - did you get your problem solved and if so how?  I have the same problem with very similar technical readings.
2 REPLIES 2
antonwelly
Message 2 of 3
hi paddyb - i have the same problem with very similar technical readings. can you help?
Message 3 of 3
you need to post the stats from your router - if hh5 go to troubleshooting then helpdesk and post 1-12
run btspeedtster and after first test run diganostic test and post results
enter phone number and post results  remember to dlelet number  https://www.btwholesale.com/includes/adsl/main.html
