Message 1 of 7
Re: No infinity 1 speed upgrade
@PaddyB sorry to jump into this thread but I may have the same problem as outlined, can you check/ help at all?, tried online chat and to be honest its pretty pointless, thanks
Steven
6 REPLIES 6
Message 2 of 7
I moved your post to start your own thread instead of getting mixed up with the other post originator
post stats from hub  if hh6 then advanced settings then technical log information
enter your phone number and post results  remember delete number but leave exchange and cab   https://www.btwholesale.com/includes/adsl/main.html
did you get the lette last year about the free upgrade
Message 3 of 7
Cheers, No I didn't get a letter, but neither did the original poster?
I can't give you stats from HUB as I'm in work but here are the wholesale results, I'm rock solid on 35Mbpsphone line stats.JPG
Message 4 of 7
if you were eligible then you should have had letter but from what you say and dslchecker results the upgrade would make no difference to your connection speed and may slightly improve your up speed depending on your router stats
Message 5 of 7
So pointless then, and as I said the original poster did not receive a letter either, thats why I rolled the dice,  thanks anyway
Steven
Message 6 of 7
I suspect, however, if you are getting a constant 35M exactly then your line has probably been banded by DLM and might achieve a bit more. Post the stats later so we can see if that is the case.
Message 7 of 7
Cheers, will do...
