Message 10 of 30
Re: Router identification
Missing cables and no bag round router and a few scuffs
going to change it tomorrow as got the old one going by squeezing the power port cable a little   into the power port (it blew the first power adapter)
if you have everything connected to internet and 5 users at weekend its a nightmare knowing when to swap over lol
Message 11 of 30
Switch on the new Hub before connecting to the Internet.
Plug a PC or Laptop into it using an Ethernet cable and enter the Hub's management pages. Change the new Hub's Wireless SSiD (Name) and the password to be the same as the old Hub's name and password and click save.
Now remove the old Hub from your Internet connection and add the new Hub. Once it has started up all your devices will connect automatically to the new Hub which saves you the need to change all your devices wireless connection.
Message 12 of 30
Do i have wifi disabled on the laptop or should it matter not as i will be connecting through ethernet
Ie will it default to ethernet
Message 13 of 30
You will need to turn off the laptops wifi as it will be connecting to the old Hub and when you try to get the managment pages it will bring up the old hubs page.
Once you have turned it off you will be able to access the new Hub's pages via Ethernet and make the changes.
You can do it all using wifi but is in my opinion quicker and easier with Ethernet.
Message 14 of 30
Which ethernet the 1.2.3.or 4 or the one that says wan
Message 15 of 30
Any of them apart from the WAN one as that is for connecting to the ONT if you have full fibre (FTTP).
Message 16 of 30
All done and well
wish fibre would hurry up here as i used to get download speeds of around 68 with a big for this area guaranteed download speed
Then after getting them out a few times and renewing contract it dropped to 45ish now its at 32 with 24 min
nothing changed but when ever you phone all you get is you are above minimum
easy to do if you keep dropping it
Openreach wholesell speed for cabinet9 in my area is 80 but that is for another day (fibre arriving next year)
thanks to all who helped me out
Message 17 of 30
All FTTC cabinets deliver 80Mb on lines short enough to get that , FTTC is rate adaptive, that means the speed at any particular location is a result of the distance from the cabinet and the quality of the copper pair .
If you once got 68Mb and now dont , that suggests a fault on the copper pair has impacted the speed , and if unresolved the minimum speed guarantee can be reduced to reflect the real world speed that cable pair is delivering, resolve the fault the speed improves and eventually the minimum speed guarantee follows, the problem is once the MSG is reduced, reporting a fault is judged against the new minimum and if the speed is above the reduced minimum it’s difficult to get a fault raised simply using ‘speed’ as the fault.
Post your router connection statistics, that will show the max attainable speed and your current sync speed , giving an indication if your line has issues .
Message 18 of 30
Message 19 of 30
Line attention suggests a  relatively short  line and therefore a speed closer to 70Mb , so I’d suspect a problem ( that’s assuming your router is connected to the master socket , preferably in the test socket to remove any chance the problem is within your address ) , log into your account ( My BT ) and perform a line test , if a defect is detected it may auto report the line for you  because if you call BT  , saying your speed is lower than expected/normal that hits the problem that this defect has existed long enough for the actual real time line data to override any mathematical estimate, so doesn’t look ‘slow’ , try putting a very near address into here and check the speed estimate for that address , does that show 70Mb+ ?
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
If an automatic fault isn’t raised by testing your own connection via My BT , you need to be creative when manually reporting a problem , or hope to get an understanding representative that doesn’t just use the MSG to dismiss your concerns, but first , if not currently in the master socket test port , move your router to it and check your statistics again.
