Newbie
Message 1 of 2
Re: Router keeps restarting, internet keeps dropping
Any update? I have the same problem now
1 REPLY 1
Message 2 of 2
I moved you post so any replies were about your problem although similar to the previous existing post may actually have different cause  this way replies will be about your problem
can you post stats from your hub  if hh6 then advanced settings then technical log information
are you using test socket with a filter?
try quiet line test  dial 17070 option 2 should be quiet and best with corded phone
